So I'm going to be having 35x12.5x20 tires installed. Is there anything special that I should do with the tpms sensors due to the higher psi on new tires?
I have the exact same tire size. I didn't bother removing mine off my stock take offs cause the factory ones arnt that expensive. Had the new sensors installed, tire place set proper psi, drove around and light never came on. 700 miles later still no issue
