1quick1
I mentioned this in another thread but I figured I'll start a new thread to document this. I noticed a decent size puddle under my truck at work. I figured it wasn't mine but got under and took a look. Looks like I have fairly significient leak coming from the rear of the transmission pan. The below taken from the drivers said and you can see the driveshaft for reference. If you look closely you can see a large drop coming from the rear drivers side although it appears to be leaking out of about 80% of the pan.
I drop it off at the dealer Thursday night so I guess I'll be putting about 50-70 miles on it with this leak. There's already fluid splattered all over the cross member and heat shielding above it. It would be nice if they clean that up as well.
2017 5.7, 8spd w/7,900 miles
