Hey all! First time poster, should have done this months ago. I need some help and opinions.
I've got some tyc projector headlights installed with retroshop resistors. So from day one I've had issues. I get an error code on my truck for the driver side turn signal. After install everything looks good then I turn the truck on and it stops working. Kicking the code within about 30 seconds. If I turn the lights on it never kicks the code but it doesn't work either.
I've talked to Jeremy since I installed and honestly I need more opinions. Cause I don't know what to do here and I'm not getting any direction.
Things I've done and tried:
Swapped back to the stock headlight. No issues.
Went to the dealership and had them reset the code. It went again just like normal.
Swapped headlights. Put in a different brand new tyc headlight. Same issue.
Swapped resistors. Installed new resistors. Changed ground locations.
Diy tipm reflash unplugged terminals and connected for about an hour and a half.
No matter what it acts the exact same. I was thinking TIPM reflash or whatever would fix it the dealer, but the regular headlight works just fine.
I read a thread where a guy had the same.issue I tried PMing him but got no response. It could be a ground issue but I don't know where would be a better ground spot.
If anybody can give me any suggestions or I put I'd greatly appreciate it.
Thanks
Thanks
