Want tires to stick out more! info!
stevens
2015 Dodge Ram sport 4x4 crew
hey all currently running a zone 6" suspension lift, with
37x12.50R20 and the rims i believe from what i seen are 20x9-1 ? XD811?
currently got bushwaker fender flares and the tires dont go past it they are under it, i want that stick out stance..nothing too stupid but just kinda normal i guess lol? whats the best option here i might get a new set of rims with a decent offset just dont know whats common to run. Like can i run new rims with new tires? something fatter than a 12.50? or bigger than 37's? or 37's that are wider. with a good offset rim....hopfully you guyes can understand what im saying here ! :)
2015 ram 1500, sport crew.
provided a picture on what i kinda want! :)
  • 15564-2-2008-silverado-1500-chevrolet-suspension-lift-75-fuel-hostage-black-hella-stance-5.jpg
stevens
stevens
37x13.50 on x12s with -44 Offset
37x13.50 on x14 with -76 Offset
wow is that a 1500? on a 6" lift ? do you rub at all? or do u get more clearance lol.
Jameson
Fort Benning, GA
It's a 1500 with 6" Pro Comp, Coilovers cranked to 8.5" and 1.5" body aloft. I don't rub.
MarshRam
Florida
2014 SLT 4x4, 2012 ST
Just be cautious if you go with the -44 offset, which appears to be what you posted, you may not clear. I'm looking to go with 37's on my 20's which sit under a 6" procomp lift on a 2014 crewcab with the -44 offset. I am not going to clear 37's on a turn. My valance had to be slightly shaved to clear the 35's when they were new. Jameson has a total 10" lift, but you wouldn't need that much to clear. I would just make sure measurements are taken first, you might be able to pull it off. I'm seeing some newer 1500's sitting slightly higher on a 6" lift, compared to mine and I suspect my front is sitting an inch lower. Gotta take off my flares and measure to be sure.
Here is a pic to give you an idea of what I am talking about. Keep in mind, these 35's are at about 30 percent tread remaining.
stevens
stevens
yeah i dont have my valance anymore! the truck is 6" lifted leveled in the front. so besides that would i be okay? any rubbing inside?
MarshRam
Florida
I honestly could not tell you. I can remove my valance or shave more, but I dont think the bumper would clear. We have different brand lift kits and I do suspect I am not level even though it looks level to the eye. Maybe go turn your tire and measure where it would actually be with the offset. Other than that, best advice I have is to take it to a lift shop and ask, should be a free question!!!! Definitely know before you do it, would suck to find out later you might have to get a little more lift to clear. And no, I have no inside rubbing issues or see that I would with 37's, bumper is my only hangup.
stevens
stevens
ty! if need be im shaving my plastic bumper! ;) tires mean everything!
JB1
Houston, Texas
do you have the rear 3" or 5" coils?
If you have the 5" rear coils you could add bilsteins up front set at 2.8 for added clearance.
post pics of your truck as it sits now, show pics of tire turned to bumper and turned to rear of front fender/door area
bryan28
Tullahoma, TN
2020 Laramie CC 4x4
Go to customwheeloffset.com and check out the galleries.
Ratket
Arizona-
Take off the bush whacker flares- that will give you the look you want and you won't have to buy new wheels-
stevens
stevens
heres some pics of current wheel cranked and how much is currently sticks out.
stevens
stevens
more
