I mounted westin 7 inch boards on a 2017 ram. I tried both methods of installing the rivet nuts. The supplied nuts when used as the instructions laid out are a pita and the nut twisted after the nut started to compress. Using one of the methods found on utube, the factory rivets worked. Use an 8mm X1.25x40 bolt, a washer with the teeth(can't remember the name) a smooth washer and a jam nut. Insert the nut screwed on the 8x1.25 with a jam nut. Hold the bolt and turn the jam nut. The jam nut will collapse the rivet without turning it. It takes a couple of minutes with no problems. Very easy. Photos when I can take them.
