WHat is This????
gbryant
Kansas
HEMI 5.7
This is the small (5mm ?) bolt that holds the speed sensor on the front hub of my 2009 Ram 1500 sport 4x4....
I have never seen a 5 sided Allen....
G
gbryant
Kansas
HEMI 5.7
Ok ABS sensor
Where do I buy a wrench for a 5 sided allen?
WilliamS
Tampa FL
To me it looks like it started life as a Torx and was destroyed from there.
I would swear my sensors were and 8mm bolt not some torx abomination.
At this point it looks like vice-grips or someone who can tack weld a new bolt on top of it.
crash68
ACME product engineer
Administrator
3.0 EcoDiesel
It may have been a Torque Plus fastener.
You may want to try cutting a slot across it and using a flat blade screwdriver.
G
gbryant
Kansas
HEMI 5.7
I beat a cheap Allen tip into it.... project done!!!! New struts!!
I now officially hate dodge engineers....
It took one full day per side.... new lower strut bushings. BTW... you don't have to buy lower A arms at $599 each, just $30 bushings and new bolts.
Now off to the body shop to fix the rusty rear fender wells... :)
WilliamS
Tampa FL
Was is the same on both sides.
Also I like your use a hammer to fix broken crap style. I do the same thing from time to time.
TRCM
USN, Retired
Newport News, VA
2012 1500 Laramie CC 4x4
Trust me....we ALL do.....some may just not admit to it so easily tho.
G
gbryant
Kansas
HEMI 5.7
Yes. Both sides....
G
gbryant
Kansas
HEMI 5.7
I use a hammer for everything.... got me out of doing the dishes. :)
