What you guys think?
Rdevil16
I have a 2012 dodge ram 1500, the passenger side running light in the back stopped working, driver side running light works fine, the turn lights, brakes work just fine on both sides, do you guys think its a fuse? or wiring? i tired to check the fuse box couldnt find anything blown, i dont want to take it in, but might have to.
Thanks,
sweet2007
6.7L cummins
Check bulb
Sent from my SAMSUNG-SM-G891A using Tapatalk
R
Rdevil16
Check bulb
Ok left a part out, i bought some brand new LED tail lights.
I attached a single bulb to it and same thing turning blinker works, stop light works, just running light
sweet2007
6.7L cummins
Test the socket to see if got power to marker light
R
Rdevil16
Actually i think it is the socket, as a test i swapped both sides and the problem moved to the other side, i think something in the socket is bad.ty
RamCares
Michigan
n/a
n/a
Thanks,
Hey Rdevil16,
If you do end up needing to use your Ram dealership for service and need any assistance, please don't hesitate to reach out to us.
Kori
Ram Social Care Specialist
