From my research the lugs on the trucks are 1.5" long. Depending on how the back of your wheel is cut out, you could get away with a 1.5" spacer without trimming the lug. If you want to avoid cutting completely go with 1.75" or larger spacer. I have a set of bora spacers sitting here (left truck at the shop today for the lift) and they are definitely well made. Many people also recommend using red loctite for the spacer lug nuts.
Sent from my SM-P600 using Tapatalk
