will the 2011 ram head lights plug in the quad lights
xariver
hey i have a 2013 ram with the quad headlights and i was wondering if the 2011 headlights will work with with the quad harness and also what all is needed use the hids and with resistors and what not i work in a body shop and was going to use factory ballasts (out of a wreck town and country) and hard wire them in any thoughts?? thanks guys
quietpeen
2021 TRX
Hellcat
the harness is different. I know 0212353(retro shop) has been looking at this for compatibility i believe up and down in years, but he can confirm later when he sees this
0212353
Vendor
Florissant, MO
2x 5.7L & 6.2L
The 11 and 13 quads are interchangable with no extra adapter.
The standard HID harness with capacitor is what you'll need. As for using the OEM ballasts......no clue the connection on that. You'll need the plug for those too.
BlownGP
Houston/Baton Rouge
You have the factory ballast?
Because a lot of OEM hids are DS-2 bulbs with the ballast and bulb all one piece.
DS-2 might work, but will need to get a adapter to work with aftermarket hid ballast
garner
Harker Heights, TX
Why would you swap 2013 quads for 2011 quads? They're the same thing
0212353
Vendor
Florissant, MO
2x 5.7L & 6.2L
there are subtle differences.
BUT.....hell, he may have a set on his truck that is all pitted, or jacked up and has a line on a great set of 13s? Who knows!
