Will they fit??
develand
Just leveled the truck 2.1 Bils.... getting new wheels this week. 20x9 Fuel Ripper in +1. After leveling the truck, it has become apparent the stock size KO2's I have are not going to cut it. They just look too small.
I am looking at going with a Nitto Ridge Grappler 35x11.5 in 20s.
Will I have any issues with these rubbing and how much further will they stick out from the 3/4" the wheels already go out?
R.L.K.
Bristol , Tn.
All the info you need can be found here Sir .
At a glance I guess with a +1 / 9" wide wheel and a 11.5 tire , I'd say your gonna require 10 mm +spacers .
Hope this helps !
http://www.ramforum.com/showthread.php?p=1087055
69GWC
Power Wagon
Spring hill, Kansas
2022 Power Wagon
6.4 Hemi, 8sp
Am I correct by saying you need a negative offset so you dont need spacers with a wide tire ?
Like a -6mm or -12mm.
I am used to just using BS to find what I am after, looks like to me a wheel with 5" BS or less is what your after, stock is around 5.50" bs on 17x8s anyway
R.L.K.
Bristol , Tn.
Yes Sir , you correct in saying he needs a - mm negative / to prevent needing spacers ..
D
develand
The wheels I am getting only come in 20 (stock basically) and +1. So it bumps the wheel out a little under an inch. Is that not enough to clear? I thought you could run those on stock wheels? Width wise.
I know -18 shoots them way out.
R.L.K.
Bristol , Tn.
I believe you are correct , your stock wheels are +19mm ( I think ) so I take back what I said about maybe needing a 10 mm spacer ...with the wheels you've chosen your -18mm from the stock set up , but your going with an 11.5 " wide tire , so it's gonna be close . I think you'll be alright .
Maybe have a set of 10 mm spacers on hand just in case ?
D
develand
Might look into the Cooper STT Pro.
12sportmc
NC
Pic is worth a thousand words right? Here is my set up 20x9 Fuel Vapors with 1mm offset and 35x11.5 Nitto G2s(awesome tires btw). Only difference is I am set at 2.8. I have zero clearance issues and no rubbing anywhere
D
develand
That picture helps tremendously!
Even set at 2.1 I do not see anything that looks to be an issue with clearance going off of this picture.
And that is the perfect amount of tire showing.
R.L.K.
Bristol , Tn.
Awesome ! A picture is worth a 1000 words !
D
develand
May end up just running the stock tires for awhile. And just going slightly bigger then stock. But not a full 35.
D
develand
I am just nervous of running the 35s at 2.1. Looks like they should fit. But appears it will be tight. Which worries me if I had to turn under suspension load.
I also though about going to 275/65. But they are all so close. I need more pictures lol
GIJoe2010
No sh*t, there I was . . .
Killeen, TX
I did 275/65R20s on the OEM wheels and the still look small with Bils at 2.8 with a 3/4" TGC spacer in the rear.
Shoulda done level then tires, since I'm pretty confident I could have gotten 35s in there, but safety was key in dumping the crappy worn out RS-As.
D
develand
My truck before and after the level. 35 I am thinking will be ok I think. Just nervous. Lot of money.
69GWC
Power Wagon
Spring hill, Kansas
2022 Power Wagon
6.4 Hemi, 8sp
Looks good, looks to be enough room in there for 35s.
12sportmc
NC
Would prob be cheaper if you can return the rims you bought and get a wheel and tire combo. Check out extreme customs . I used them for my setup and saved a ton on my rims and tires with new Mopar TPMS installed and already mounted and balanced. I just had to put them on my truck and drive The customer service was great Not sure if this is the finish on the rims you ordered but that's a great deal on the combo. Just an example
VLG6963
