wind noise
Bigpoppa14
I have a 2014 1500 CC 4x4 , at about 70 miles an hour I have a wind whistling noise some where near the front drivers side windshield. I have a bug deflector on the front. Anyone else have this problem?
jsteinm1
Nebraska
2014 Ram 1500 Sport CC
HEMI 5.7L
I have a whistling sound, but I'm almost positive its the aftermarket antenna I put on.
B
Bigpoppa14
It might be mine too ,I put about a 12 inch black powdercoated one on there what did you put on ?
HemiRoar
Toronto
5.7L Hemi V8
remove it and take said 70 mph drive again. a lot of people have mentioned wind noises with shorter antennas as they don't have the OEM antenna style grooves.
The Q
South Texas RGV
2014 Sport R/T
My OEM antenna whistles at highway speeds. It has the spiral wrap, but the last 1.5" of the top part is nearly flat.
Riccochet
Somewhere around Charlotte
2020 2500 Laramie Longhorn
My driver side whistle is my door window seal. With the window all the way up at stop it'll whistle. If I just barely tap the window down it'll stop, but is still sealed.
I don't care enough to take it to the dealer so they can tear it apart and make it worse. lol
BlownGP
Houston/Baton Rouge
My wind noise seems to coming from my rear window somewhere. Mines a 09 but bugs me sometimes even with my loud exhaust..lol
shmedley
Downers Grove IL
I had the same noise when I had that same antenna. Took it off and it was gone.
Another thing to check is the mirror. I've have head of that a few times. Mine was finger tight when I checked
cgeorgemo
Joplin, MO
3.6 Pentastar
My wind noise appeared when I put on the AVS in channel vent shades on my truck. It's not loud or obnoxious, it's just there.
It wasn't until I installed the vent shades. Your's might be the same thing.
BlownGP
Houston/Baton Rouge
Could be right... I might need to look into that..
Thanks
Steven
VLG6963
