Hemi Joe
- Mar 22, 2012
- 710
- 58
- Berks County, PA
- 2012
- Hemi 5.7
Went well, love the USB port.
Hey Joe, looks really clean! Can you tell me what options your express came with? (ex. bluetooth, sat. radio) I just got a 2012 express bone stock. Has power door locks & windows but no keyless remote entry(could add it), no cruise control. How much did you spend on parts, easy or hard mod? Thanx!
looks good
That looks really good. Did you do it yourself?
Yes, I can post the part numbers I used later if you want.
Thanks, I appreciate that.
When I get the parts I was planning to use a "Whale Bone" plastic tool to pop off the plastic parts.
Is the bin held by plastic pop off fasteners or are there hidden screws I need to look for?
I look forward to charging the iPod and cell phone through the USB port. My truck came with U-connect so the right connections should be taped to the harness behind the bin.
Does anyone know if 2009 had that USB taped behind the box. I have the Nav radio and I connect but my glove box has no USB like that. I installed the iPod connector but would love to have USB way instead.
$miley
It's easy to remove. Just remove the lower glove box by squeezing the sides in and dropping it down. Then look up underneath, there's one screw to remove and it pops out. The hardest thing about the whole thing is getting the uppre glove box door in. What a PITA that was. Oh, one more thing, I had to go to the hardware store and buy four trim screws for the upper door. They're the same size as the screw that held the upper bin in.
Here's some more links if you want to read more about this.
http://www.ramforum.com/f17/1st-mod-new-express-12199/
http://www.ramforumz.com/showthread.php?t=47705
