Added USB Ports!
Dantheman
South Carolina
So since everything is charged with a usb cable now and there weren't any ports in the back seat, I added this.
I just mounted a little distribution block and used the power from the existing jack. I also had the jack in the center console that needed to be rewired. Also going to the block are wires for a CB and ham radio but aren't in any of the pictures.
Mineralram
Nice clean install
Sent from my SM-G900W8 using Tapatalk
Litenyaup
Where did I get the usb cluster?
Drummin4jc
WWG1WGA!
SW Pennsylvania
2024 Ram 2500 CC
Nice job! I take it these are for power only (charging), correct?
Adam
kg93
AZ
ill definitely be doing that when i eventually swap in a center console. I hate having people in the back stealing my cords and having wires everywhere
thoss29
Middletown, RI
2015 3500 "Black Top" Edition 6.4L
I know I could walk outside and find out for myself but it's cold outside; are these always powered or do they have to have the key on?
Dantheman
Dantheman
South Carolina
They have to have the key on. I thought about having them always on but sometimes the truck sits for a while and I don't want to kill the battery.
tojo
Putting this on my list of things to do! Thanks!
Sent from my SM-G920P using Tapatalk
reloaderguy
Oregon
2016 Power Wagon
Can anyone advise where to tap power in the rear of the cabin for Crew cab 40-20-40 Laramies?
tojo
You'll have to run a line from the power port up front in the dash.
reloaderguy
Oregon
2016 Power Wagon
I was hoping there was power under one of the seats. It would make more sense to splice the power in the center arm rest than run it from under the dash. Unless I'm missing something and there is a dedicated accessory power circuit under the dash?
