I just talked to the dealership and was informed that if I brought it in they could clear the airbag warning light quickly and for no charge. He informed me that if the airbag warning light stayed off after that, then I was good to go. If the airbag warning comes back on after being cleared, then we definitely have a bigger problem.
Airbag light will go off when you have fixed the problem. No need to reset. There is a problem with the airbag, clock spring or the wiring in there.
