Can I swap radios?
brasso
2012 ram 1500 4x4
Im seeing where some guys are changing their factory screens from 5.4 to 8.4 or whatever… my question is: Can I do this to mine?
I have a 2012 ram 1500 lone star with the small factory screen.. Is there any way I can change to a bigger factory screen?
Ram3
2012 Ram Sport CCSB
I'm trying to find that out too?
Jared4.7
Olathe, KS
2017 Bighorn CC
You can swap in any radio you want but it can't be newer than 2012. I put an RHB with nav in my 09. Everything worked, just make sure you get the unlock code.
cgeorgemo
Joplin, MO
3.6 Pentastar
I believe you would need to swap from an RES to a RHR, RBR or RB2 radio in order to get a larger screen.
From what I've seen on the back of them the main connectors are the same but there are some connectors that are different or missing on the RES
I do not know for sure because I only have experience with the 2013 and 2014 radios.
Ramzaq
Northern California
2009 CC 4X4 3.55 Big Horn
2013 and newer are not compatible with 2012 and older.
Below is a selection for your 2012, also you will have to get a radio with a high speed can bus, a low speed can bus will not work in the Ram.
Owners - Quality - Media Center 430 (RBZ)
All these radios will work in your 2012
2011 they did a manufacture change for the radios and updated the software and some hardware so try to get an updated one.
B
brasso
2012 ram 1500 4x4
Id like to get one with nav and a bigger screen if possible.. I was really hoping I could get one like what comes in the longhorn or laramie but I don't see that being possible
baum
savage, mn
2015 Laramie
your best bet is to look into an aftermarket unit then. it will also give you much better sound also.
