Center Console Lid(s)
Kapt
3L
Mine is very loose in my 2016 Laramie. Anyone know how to tighten it? I would take it to the dealership and have them do it since it's under warranty, but the local Dodge dealership closed, and the next closest is over an hour away
quietpeen
2021 TRX
Hellcat
There is the cover on the back of the console that pops off if i remember correctly and then there are the screws that attactch the lid to the console
Kapt
Kapt
3L
Awesome! Thank you. I'm gonna go look right now
Kapt
Kapt
3L
Can't find anything that pops off. In fact, I can't find access at all
Kapt
Kapt
3L
Anyone?
bpd138
Any updates on this? I'm having the same problem. I just installed a backup cam with PAC BCI-CH41, pulled the dash apart, removed the radio etc and for the life of me I can't figure out how to get to the screws that attach the console lid.
bpd138
OK, I figured it out. As Quietpeen stated, the cover on the back of the center console just pulls off. Grab the bottom right corner and pull and it will come away. Once the cover is off you will see the screws to the main hinge.
To get tot he screws for the top lid hinge you have to remove the lining inside the lid. This is done by removing the 6 #20 torx screws and pulling the lid liner out. The screws that secure the lid to the hinge are also #20 torx.
