do 100% of rams that have the 8 speed have the knob?
jon0m0berry
i was looking at possibly getting into a newer ram than the 2010 I have now. I was under the impression that if it had an 8 speed, no matter what, it had a shift knob. were the 5/6 speeds have the column or console shifter. but i've seen a few ram sports that claim to have the 8 speed but they have a console shifter instead. I was wondering if maybe in certain models, such as the sport, that they can have the 8 speed without the knob
Eestee70
Chicago
All of the 8 speeds I've seen have the knob
Patrick_O
Hemi 6.1
Suppsedly they will be going back to a conventional console mounted shifter for the 2019 model
cbsmith
New Brunswick, Canada
2014 Ram 1500 Outdoorsman
All 8 speed have the knob. If it is a column or console shift it is a 5/6 speed.
00R/T
CT
Like everyone said, the knob is the only shifter for the 8 speed. I'm guessing the trucks you're seeing are 13s. A 13 could have either transmission depending on when it was built, and that's probably confusing the listing system a lot of dealers use. For 14+ you had an option of which you wanted on the lower trim HEMI trucks like the Express, but I believe all Sports, Laramies, etc. were 8 speeds at that point.
Broyd
Rossland BC Canada
If your only choice you could get was the shifter knob, would this be a yes/no criteria for moving to a newer model?
Express SN95
Maryland
It would be a resounding yes. The 8 speed is leaps and bounds better then the 6 speed. That is not to knock the 6 speed as it wasn't bad at all in my old 2012, but after having moved up to an 8 speed in a newer truck I can say it's a better transmission. The shifts, the power delivery, etc are just better. Now, in earlier trucks there were some shifting issues that was mostly resolved by a computer update. I think most people get hung up on the knob (which IMHO I would prefer an actual column shift) but to get the better transmission i'll gladly put my truck in drive with the knob.
crash68
ACME product engineer
Administrator
3.0 EcoDiesel
Even if RAM was to switch back to a column or console "shifter" for the transmission, it will still be a shift by wire like the 8 speed trans now.
HEMI_Finn
U.S. ARMY Veteran
N.E. Ohio
I thought the knob was model year specific? FWIW my '14 Sport has the 8 speed and the knob.
barr0208
winnipeg manitoba
2019 ram 1500 sport long bed
5.7 3.92 4x4 ruby red
I think this knob issue has been discussed and discussed :roflsquared: get an 8 speed with it or buy a used 6 speed shiiiissshhhh
1quick1
Colorado
I enjoy the center console space it saves and I don't really care for column shifters.
Sickem
2017 1500-Express 3.92's w/ anti-spin
I was concerned as well, but I rented a Durango and after my trip, I decided that I like it. You get used to it quick.
