Gauge cluster question
countryboyco99
Any one else had this problem and if so can it be fixed inexpensively? Or does this indicate a problem with my transmission l? 4718c5f8041c37f4eb11e9ddf9ce10fb.jpge8d30fea8d1ed63a76536521db722f36.jpg293bfc327d6adb32704c2f13ed6e39e9.jpg
It seems to do it more in the afternoon when it's really hot out
2010 Dodge Ram Quad cab 1500 4.7 with 3.55 gears.
R.L.K.
Bristol , Tn.
What is the problem Sir ?
C
countryboyco99
The "D" light does not come on sometimes and when it does it goes out after a few minutes.
R.L.K.
Bristol , Tn.
Lol I see ? Hmmmm
Does the drive gear always work ?
Have you ever had your cluster removed for any reason ?
Does the + / - work as normal?
You have the 6 speed 45RFE correct ?
How many miles ?
Is it hard to get out of park ?
If you jiggle the shifter arm does the D light illuminate ?
Have you ever had to jiggle the shifter to get the Engine to crank ?
Does it matter what the column position is in ( all the way up , middle or all down ?)
Sorry for all the questions .
C
countryboyco99
Ok I'm going to try to do these answers in order of you questions.
Yes
No
Yes
Not sure I think it's a 5 speed?
Roughly 97,000
No
No
No
No it's doesn't matter what position the column is in
R.L.K.
Bristol , Tn.
I'd say your intermittent green D is just a nuisance at this point . Likely culprit being the instrument cluster itself or shifter position sensor .
Either way no issue with the xsmn imo .
When power is on in a vehicle the most used position is the D position , @ 97k that light has been on thousands of hours and the circuits to make that light come on are just showing their age .
Instrument lights on my last Dodge started going out or intermittent at a little over 100k .
Hope this helps !
C
countryboyco99
Is there a was to replace the bulb or is it an led soldered to the board?
R.L.K.
Bristol , Tn.
Not sure , try Google & youtube.
If it's intermittent it's probably not a bulb .
C
countryboyco99
Thanks for the help.
