Gauge Faces
B
bubbasneed
Cincinnati OH
I am going to keep an eye out for a broken cluster that is in MPH or KPH if it is cheap enough and just try and remove the tach face. If that works I will just put it in my current cluster.
I am still going to have the dealer check the mileage and hours and compare it to what the cluster is reporting and I hope there is no discrepancy. I have to take it in for a recall so I will have them do it then. Does anyone know if they charge for this service?
Cesar592
3.6 pentastar
You can swap to the correct lens and mask very easily. It's around $75 to replace new. I have a damaged one I'll give you to see if it corrects your problem if you pay for the shipping.
Sent from my HTC One using Tapatalk
Hello good afternoon to all the forum a preguta where you got the gauge faces is that eh tried to get them but I do not know the part number you think you can help me to correct this my cluster brings kilometers and I want to replace the faces to miles
SitKneelBend
St. Louis
3.6 Pentastar
Unfortunately, the faces are not swappable on 2013+ Ram trucks. Only the surrounding bezel and lens.
powderbrad
Edmonton, AB
I'd be worried about what else was "fixed" as well.
I swear dealers don't even look at these vehicles.
