Gauges from a limited into a sport/Laramie??
MACH
Anyone tried switching out the Sport/Laramie gauges with the better looking ones of the Limited??? I like the look of the limited speedo and tach.
Did a search but can't find anything on it.
xrsman
Ontario
3.0 Ecodiesel
If you look in either the interior section or audio and electronics section you'll find a very detailed thread on this! There are a few guys who have done the swap
xrsman
Ontario
3.0 Ecodiesel
My bad, thanks for the correction 14hemi!
apepe0738
Peoria, Arizona
2012 Ram 2500 Crew Cab 4x4
Since you already have the upgraded cluster, I would see if you could just swap the skin from the gauges. That way you still get the look you are after but you don't have to worry about all the mileage stuff...
Hrolfr
I believe it is a sealed unit.
Jared4.7
Olathe, KS
2017 Bighorn CC
Lens will come off (I replaced the entire lens/bezel assembly on my premium cluster) and you can pick the needles off if you want to. Applique will just peel off too.
MACH
MACH
This is what I really want to do. I don't feel like replacing the whole dash.
