jtstj
- May 22, 2014
- 15
- 14
- Colorado Springs, Colorado
- 2014
- 5.7 hemi
Ive done some searching on google and here and cannot find my specific problem. Here is what is going on. When I put the heat in defrost mode, it works on defrost perfectly. When I switch it to floor only, it still blows a little out of the dash defrost vents along with the floor. Its as if floor only is doing the floor and defrost setting. I spent last weekend opening up the console and looking at the Actuators. They are both working and move when the controls are switched. The actuator that controls defrost and floor seems to work fine, I even opened it up to see if the motor hangs, etc. It looks fine. What I did find was when it goes back from Defrost to floor, it stops short. As if the juice is getting cut off before the servo when it returns the blend door to the floor. If I take out the screws to the actuator and hold it in place, then switch from defrost to floor, as soon as I pull it out, the blend door moves a bit more to the full position for the floor.
I played around with this for quite awhile, I even swapped out the actuators and they both do the same thing. They dont quite return the blend door to the stop that would force the air fully to the floor.
Anyone else have this issue? Is the HVAC blend door actuator signal programmable by the computer? Im so tired of heat in my face!
