This is on a 2016 Ram Tradesman regular cab.
With the vent selection in the 12:00 position, and the fan cranked up, I don't seem to be getting much air from the heater vents. You can hear the fan making a sound somewhere in/under the dash that would give you the impression that its putting out a lot of air. Just wondering if some vacuum hose isn't connected.
Eventually, the cab heats up.
Is this normal and if not, what should I check/test to correct it?
With other vent selections, I get a pretty good air flow from the upper vents.
