Help Needed - Map Lights
N1ck
Regina Sk
I purchased some led's for the map lights, seems like an easy job. Pop the over off (left side, bottom one since the pic is turned over) and can't seem to figure a way out to safely pop the other piece off...
Also changed my license plate bulbs, all working but when I turn the truck on I get a 'license plate light out' warning message. Kind of a **** off, I didn't have either of these issues on my 2013!
Tach_tech
5.7L HEMI
As for the light out message. It's likely because the LED lights have a lower resistance than a conventional bulb. Some times you have to get the LED lighting sales code added by your dealer.
N1ck
N1ck
Regina Sk
Thanks for the reply, I did see that before I made this thread.
I have removed the lens, see my photo. My issue is there is a reflector or something under the lens, I do do have access to the bulb!
EagleChief
Oklahoma
2014 Big Horn
Yep, you already have LED's I believe. It's tough to change them out by reading his thread, but doable.
JCJ4290
2014 CC 4X4
Couldn't you just change to the non-led and upgrade those?
