Pigeonman
- Mar 27, 2014
- 645
- 166
- Alberta, Canada
- 2014
- Hemi 5.7
https://www.youtube.com/watch?v=FWxqOe_LHDQ shows you everything, down to taking the cloth cover off if you wanted to
Why not just tap into the wires under your seat that go to the outlet?
The plastic around the cup holders just lifts up. It's held in with clips. After that you'll see everything you need. Just pull up on the plastic
I just changed the upholstery on my center console just like that one. In order to get to the wiring you have to remove the fabric, it pulls out of the channel that goes around the lid and pull the cup holder off as well, then you can access all the wiring from under the foam.
