Illuminated sill guard
crazykid1994
crazykid1994
Florida
I'm looking for something with a factory fit and there really aren't any pictures of this that I can find.
MaizeNBlue
Yup.... ridiculously over priced, but I do like em
MaizeNBlue
Yeah sure can ... they basically just sit on top of the plastic molding. ..held on by 8 little screws...they are not form fitting by any means ...will get you some pics when I get the chance
MaizeNBlue
As requested
crazykid1994
crazykid1994
Florida
How well do they seem to be holding up. I don't like that you have to screw them in is the only thing. Illuminated steps are so cool though
charonblk07
Calgary, Ab
F1-A forged 349ci
I ended up modding my sills to get them to sit flush, I hated how they would sit up with how they were designed. Plus, I wanted them to match my interior so a few LED strips and difusing orange film and I had my own sills. I later installed a similar flat illuminated strip in orange to get rid of the hot spots.
crazykid1994
crazykid1994
Florida
Damn that's nice. What'd you do to make it flush? I might have to do that.
charonblk07
Calgary, Ab
F1-A forged 349ci
You can see in the 2nd pic. I ended up trimming the plastic door sill to fit the Recon dolls flush. I bought a second set of oem sills to cut up and paint. The 4th gen sills are different and should actually be easier to modify.
The other option is to make your own sills using the mopar chrome door sills and some electroluminescent strips/EL Tape. That's what I'm doing in my new truck.
crazykid1994
crazykid1994
Florida
I might be thinking about a plexiglass lens with led tape under and taking a Dremel to cut out the ram logo. That's not a bad idea
MaizeNBlue
Oh I like how this sit much much better! .... we shall talk lol
charonblk07
Calgary, Ab
F1-A forged 349ci
MaizeNBlue
Did you just cut a "trench" in the plastic sills so they would sit lower ?
charonblk07
Calgary, Ab
F1-A forged 349ci
Pretty much. There's a plastic cover over the wiring harness under the oem sill that you can screw one side into, just use a screw just long enough to go through the illuminated sill and into the wire cover but not through it. I believe mine were only 1/2" long, the other side goes into the lower door seal
