K/C rocker switch install
Rotzilla
colorado
6.7 CTD
Where did you install your auxillary rocker switches?
crawling all over the place and can't seem to come up with a suitable spot.
Pics if you have them
Thanks
quietpeen
2021 TRX
Hellcat
bump for somebody that has done this
0212353
Vendor
Florissant, MO
2x 5.7L & 6.2L
do you have the center console?
Musclemckeester
Houston, TX
n/a
n/a
I've got mine mounted on the side of the center console, but since that isn't an option I'd say mount them maybe below the steering wheel. I think I've seen them put there - or if you don't have the 4x4 knob I've seen people put switches there too.
Rotzilla
Rotzilla
colorado
6.7 CTD
I had it mounted lower on the dash L. of the steering wheel, however occasionally it would get hit by a knee and turned on. Pulled the center stack around radio, everywhere I wanted to put it something interfered from behind.
jwilliams82
Michigan
There's no room on the dash below the radio where the unused accessory switch covers are? I would think there must be some room behind there for wires because things get wired there from the factory. Or is the switch too big?
HKkid
Missouri
I've got mine mounted in my custom center console, you could make a plate to go in cubby and put them in there.
Big Boi
S. Fla
I mounted mine just behind the pull handle for the e brake. So its "hidden"
Big Boi
S. Fla
^ Pics or it didn't happen! :********:
The wires arent as bad as they look in the pic. It was the camera angle
And keep in mind, even if you eye level with the e brake handle, you can see the button.
wermbang
Iowa
2001 Off Road
5.9L V8 Sport
thats pretty neat
