Where did you install your auxillary rocker switches?
crawling all over the place and can't seem to come up with a suitable spot.
Pics if you have them
Thanks
I've got mine mounted on the side of the center console, but since that isn't an option I'd say mount them maybe below the steering wheel. I think I've seen them put there - or if you don't have the 4x4 knob I've seen people put switches there too.
I had it mounted lower on the dash L. of the steering wheel, however occasionally it would get hit by a knee and turned on. Pulled the center stack around radio, everywhere I wanted to put it something interfered from behind.
There's no room on the dash below the radio where the unused accessory switch covers are? I would think there must be some room behind there for wires because things get wired there from the factory. Or is the switch too big?
