Ram Man
Well I did it! (Driver side done, passenger side is almost identical process, in the mail)
Huge thanks to Benny for supplying the parts needed and answering all of my questions throughout this project!
The part numbers for the door panel bezel with leds are listed on post #31 of this thread.
Stock sport handle bezel vs laramie bezel with led
Behind the door panel is your door module brain that controls everything (mirrors, windows, etc).
C5 connector is what you want to use
The new led comes with a plug on the end that I snipped off immediately. What you're left with is a positive and negative wire, pretty basic. I soldered an extension 20 awg wire to it then on the other end soldered a connector pin so that I could populate the C5 connector. Huge thanks to Benny for this info! I looked ALL over for days and came up with nothing. You want to populate pin 3 and 9. Make sure you test which wire goes to what pin before you make it permanent. To test it just put the pins in and twist the headlights on, if the led turns on youre good to go. If it doesnt swap them and try again.
