Leaking rear window?
GreenClassic
Las Vegas, NV
2015 Big Horn CC
Why can't they figure out a fix for this after all these years? It's such a common problem, it's ridiculous.
jbr
jbr
Long Island, NY
I sealed the third brake light on Friday 1/2. It poured on 1/3 and 1/4. No leaks!! I replaced the bulbs in there also with LEDS from Superbright before I sealed it. [emoji1]
Burla
2010 Hemi Reg Cab 4x4
Mine leaks too, fawking Dodge.
Rodallg
CA
Mine leaked so I went into the dealer and at first they thought it was the window leaking until I went to pick it up and of course they tell me it the brake light that leaks and they have seen a number of them the same way.
When I took it in I told them I read in some forums that the brake light is leaking on the Rams, he looked at me like I was a freaking newbie and didn't know a darn thing.
SouthernBoy
Central Texas
Seems to me if you get one of these trucks, immediately reseal that third brake light as a precautionary measure.
GreenClassic
Las Vegas, NV
2015 Big Horn CC
Once I get my truck, I'll be replacing the bulb with an LED. Seal it up good and never have to touch it again (hopefully).
AzRamLover
Jumping on this bandwagon - I had a really small leak that manifested under high pressure drying from car washes (normal rain, etc. did not cause the issue).
The dealer did repair and replace of the 3rd brake light, along w/ reseal, no charge.
