Led interior lights
gray8188
tampa, fl
Hey guys bought some interior led map lights and the lights for the rear from superbright led and they wouldn't work right. Read up I may have to use a resistor or something. Not really wanting to deal with it. Anyone have a link of the exact led lights I need that I can just put in and they will work. No extra work needed? Thanks.
SitKneelBend
St. Louis
3.6 Pentastar
This is what I use, you can go one size larger than these in the map lights...
Cutequeen 10x LED Car Lights Bulb White T10 5050 5-SMD 194 168 https://www.amazon.com/dp/B00ALQQNHC/ref=cm_sw_r_other_awd_FLVhwb57E6AE9
Sent from my HTC One using Tapatalk
G
gray8188
tampa, fl
SitKneelBend
St. Louis
3.6 Pentastar
Awesome thanks. What would the next size up be? And what about the lights over there rear seat?
Size larger ( I have these in map, and rambox lights)
http://www.amazon.com/Cutequeen-Tra...UTF8&qid=1444935877&sr=8-1&keywords=cutequeen
The dome light I originally had a cutequeen, but I replaced it with this super bright one when I switched the map light color to red to save my night vision...
http://www.amazon.com/gp/product/B00N4M95XO?psc=1&redirect=true&ref_=oh_aui_search_detailpage
KahneFan
Buda
Amazon.com: Cutequeen Trading 10pcs LED Car Lights Bulb White T10 2835 20-smd 400 Lumens 194 168 (Pack of 10): Automotive
And threads like these are where I spend money I wasn't even looking to spend on a problem I didn't know I had :roflsquared:
KahneFan
Buda
Done! Even in the daylight I can tell a big difference. BTW, I'm in Buda, TX and now have an extra 8 map lights if anyone needs one :) (they came in a 10 pack).
KahneFan
Buda
Oh yeah and, the map lights are directional, so be sure to test them before you put everything back together. I tested mine each time and sure enough I had them in backwards.
SitKneelBend
St. Louis
3.6 Pentastar
Sorry, forgot to mention that...
CMil527
Old Bridge, NJ
2021 RAM 1500 LARAMIE-CC
much better! :favorites13:
Donelam304
Madison, West by God Virginia
HEMI 6.4
On these lights. I'd like to go to a red interior light as well. Those of you wondering, Yes, it does make a difference in night vision. I'd go with a blue/green if I could get them that color. But I'm sure no one make a NVG compatible led light for these. Lol. Do you happen to have a part # for red led's.
SitKneelBend
St. Louis
3.6 Pentastar
Just click the link and there should be a color option. If not search Amazon for "194 cutequeen red"...
Milt IV
TX M'F'er
2015 Sport
I could use a couple of the map lights. I'm in Grand Prairie TX.
For the rear dome did you use the one from the link above? Do they match in color to the ones you put in the maps?
KahneFan
Buda
Yes, I used THESE and THIS and they match. At least, they match well enough that I don't see a difference.
Milt IV
TX M'F'er
2015 Sport
On the cutequeen link you just provided did you buy the white housing 20smd or the black housing 5smd?
RedFalcon
Katy, TX
I might have to swing by and try to grab a pair from you next time I drive up to San Marcos
KahneFan
Buda
I purchased the double stacked white.
Sure thing. I'm about 10 minutes north of San Marcos just off I35. PM me and I can give you the address. Also, if you're not already aware, you will only be about 2 miles from Cabelas.
KahneFan
Buda
Attached is a picture of the light, plus a nickel for size comparison.
acwood04
Since I only have the rear dome light, I've taken it upon myself to run some single diode LEDs in my headliner, which i ran to a switch next to my light bar on my bull bar bumper guard coming from a relay. It's like the luxury BMWs and Mercedes that have "ambient" lighting. Got the LEAD bulbs off Amazon and the 5mm flush mounts. Pretty cool mod. ImageUploadedByTapatalk1445404767.716545.jpg
