Hey guys I need a little help. I have a 2016 dodge ram sport. I am trying to replace the map lights with LEDs that I had just purchased. I popped off the clear cover and it seems to me I have to pull down the entire council just to replace two bulbs. Can somebody please tell me if this is correct before I wind up damaging my truck. These are the bulbs that I purchased let me know if they are the right ones or the wrong ones the company seems to be no help to me at all. Thanks for your help in advance. The number to the bulbs are 4410-NW8-CB. I purchased these from superbright LED Inc.
For the map lights, the clear cover will come off easily, just gently pry from the edge with a small flathead screwdriver. Note the orientation of the hinge or whatever you want to call it for reinstall. (edit - I re-read your post and saw you already got these off)
The bulbs pictured are meant for the dome light and will not fit the map light. Do you have the rear dome light? If so, you should be able to use one of these there.
If you insert it and it doesn't work, reverse the direction and it should come on.
Now for the map lights, you need a 921 bulb equivalent. These are a push in type bulb. The OEM bulbs are a pain in the **** to get out due to room. What I did was take a pair of pliers and wrapped the ends in tape for some padded grip. With gentle pressure they pulled straight out.
Let me know if you have any questions, I just did mine two weeks ago. The map light bulbs are the same ones that work for the license plate bulbs as well.
Also, this is a good link to print/bookmark for our bulbs:
http://www.ramforum.com/f75/bulb_list_4th_gens-8964/
