Read alot of the threads about lock actuators and they all say check the wiring first most people have a broken wire. Well I checked the wires and found no cut wires. I can manually lock and unlock the rear drivers side door, but it will not work off power. I took the outer door panel off and found a small 3x3 inspection cover by the actuator, but could not see the actuator or figure how to get it out to see if it was bad or had a bad wire connection. Looks like if you took the inner panel off you could easily access it but can not figure how to do that. Any help would be greatly appriciated. Thanks Tom
