Map lights install help
xrsman
Ontario
3.0 Ecodiesel
I thought there were bulbs...what is this? How do I take it out so I can put my LEDs in?
jbr
Long Island, NY
http://www.ramforum.com/f42/2013_map_dome_light_help-28711/
Its seems that the replacement is more complicated than I personally thought. I was going to order from superbrightleds, but I am having doubts now. From what I have read on different forums is the chrome piece has to be removed to access the bulb, but seems to replace it is a little complicated. The rear dome is attach to some kind of circuit board.
jbr
Long Island, NY
xrsman
xrsman
Ontario
3.0 Ecodiesel
cgeorgemo
Joplin, MO
3.6 Pentastar
I just use a small screwdriver to pry off the clear map light cover. Which allows me access to the bulb.
For the rear dome I use the same screwdriver to pop off the clear cover.
Is your setup different than mine?
xrsman
xrsman
Ontario
3.0 Ecodiesel
Yeah mine is different, the chrome part is flat. The rear dome light is the same as the front map lights. I need to somehow remove it to access the light. In the link JBR shared the guys were talking about removing 3 small pieces to get it out.
What I think I'll do is just get the dealer to put them in when the truck goes in on Wednesday lol. Save me from breaking something!
Thanks for taking the time to get me pics man!
Ram83
British Columbia, Canada
2014 Ram Sport
did you get this figured out,,,i got some leds coming in and have the same map lights as you
xrsman
xrsman
Ontario
3.0 Ecodiesel
No I haven't yet. I have the truck going into the dealer tomorrow so I was just going to get them to do it. I'll update tomorrow night with the results!
Rherman1
Sunny Florida
6.7 Cummings
What bulbs did you use for the map lights and dome light, and did you get a bulb out message?
cgeorgemo
Joplin, MO
3.6 Pentastar
The bulbs I used are just some LEDs that I bought in a kit off eBay.
I don't believe that the interior lights are monitored for bulb out errors.
xrsman
xrsman
Ontario
3.0 Ecodiesel
see if you can see how they did it
Just got a call from the dealer. They told me that my lights are actually hardwired in and they can't replace the bulbs. The tech even broke he rear dome light trying to get into it so they've had t order a replacement. Guess the upper trims can't be changed! What a bummer!
Ram83
2014 Ram Sport
so i just wasted 80 bucks on leds???? so everytime a bulb goes out we have to take it in the dealership?
you would think they would alreday know that before trying to change them
xrsman
xrsman
Ontario
3.0 Ecodiesel
Well maybe your truck is different than mine. It's just the map lights and rear dome light that you can't change on my truck. I replaced the reverse lights and third break lights already
Ram83
2014 Ram Sport
my map lights look the same as yours
Pigeonman
Alberta, Canada
Did you have to run a resistor for the third brake light or use CANBUS friendly led's?
xrsman
xrsman
Ontario
3.0 Ecodiesel
That sucks man :/ you'd think they would make it easier. Idk why anyone would want that ugly dull yellow colour.
No I used canbus bulbs. The only lights I bought that I couldn't get canbus for were the reverse lights. I used a resistors for each of those though.
