Just had the same problem with my 2014 SLT just had a tropical storm role threw came out this morning and low and behold stains in both rear corners was not wet to the touch can anyone confirm that it normally is the third break light
I have a 2016 Ram 2500 Laramie mega cab with a sunroof and I have noticed leaks in multiple areas. I've had water come from the driver side grab handle , overhead console, and the area under my radio filled up with an inch of water. I have 8000 miles on it and it's less than a year old. I will be scheduling to take it in shortly and I'll update the post as to the conclusion.
Truck had been sitting in my level drive way in a steady rain. I put it in reverse to back out and water began flooding into the cab from driver side handle by the windshield. The water had obviously pooled in the headliner. The first thing i did was check the sunroof and it was closed. I took it directly to the victorville motors . They took the headliner out and told me they couldn't pinpoint the problem. They couldn't charge the corporation for inspection because they didn't fix a thing so they half hazardly put my interior back together and now my headliner is hanging a inch from where it should be attached and is rattling. Proper tool was not used for taking the overhead lamp assembly out so now there are tool marks. My truck is now worse then when i took it there. I will allow reluctantly allow the service department to remedy the sloppy work performed by a tech who has no pride in what he does. This has been my first Ram purchase experience.
Hi CaliJoe,
Sorry to hear about this! I'd be happy to follow up with your dealership for you if needed. Just PM our page with your VIN and let me know.
Andrea
Ram Social Care Specialist
