RCFiddyOne
- Jun 18, 2013
- 289
- 90
- 2015
- 5.7
Absolutely GREAT idea. You guys come up with the best ideas.
The video you posted shows the holster sliding forward, backward, and lifting until the belt hook catches at the top of map pocket lip. It as also dependent on having a center console.
I installed the Aliengear mount for paddle holster.. it's not in the way, but well in reach.. there was drilling involved.. but worth it in my mind..
Forward and backward movement only happen when I'm literally moving it with my hand, before holstering the pistol. Once holstered, the weight of the pistol holds the holster in place (the seat also prevents backwards movement)
The slight lift before catching is a non-issue, IMO. What matters is that it catches. I also use a SnagMag (magazine holster) which employs the same concept of a "snag draw."
Dependence on a center console is a good point though. Thanks for sharing your setup.
I have the exact same setup and mounted in the same space. I carry my Ruger SR9c there. Can not be seen from outside of the truck. I also have an IWB holster, so sometimes I just switch from the gun from the paddle holster to the IWB.
Pistol looks fairly elevated...enough for the passenger to see? I prefer a bit more concealability, but nice setup either way!
Loose holsters are pretty unappealing. Other than cost it is just cheap.
Here is the no-drill system I came up with, just remove the M8 seat bolt and install the Ram 1" M8 ball.
Dara custom kydex holster
Ram 1" M8 ball
Ram 6" arm
You can adjust the mount to point sights forward for center console trucks. This is a solid mount, no movement or rattling. I throw a beanie over the pistol to reduce visibility when I want.
Ram 1" M8 ball
Ram 6" arm
Ram 1" M8 ball
Ram 6" arm
And people wonder why no one wants to invade the USA.
I love this made up WW2 quote!Behind every blade of grass....
