Go Back   DODGE RAM FORUM - Dodge Truck Forums > Dodge Ram Generations Forum > 4th Gen : 2009 - Present > Interior
Interior
Part#s needed - 911/Assist auto dim mirror covers
This is a discussion on Part#s needed - 911/Assist auto dim mirror covers within the Interior forums, part of the 4th Gen : 2009 - Present category!
Originally Posted by Mega-Hemi Is there a difference between the '14-'16 mirror and a '13 mirror? As far as I ...
Like Tree3Likes
Reply
Old 09-12-2016, 10:36 PM   #11 (permalink)
Mpgrimm2's Avatar
Ram Year: 2013 SLT Crew
Engine: 3.6L V6 Pentastar
Default
As far as I know there is not.
PS: I have a How-to Install the mirror and harness instruction sheet in the 8.4 Radio conversion thread linked previously.
- 2013-2016 Ram RearView Mirror (w/mics) Upgrade & Harness install 7-8-16.pdf
From my Up All Night Sleep All Day Gs7 on Tapatalk
Sponsored Ad
Register to remove this ad.
__________________
Help others out and post about about 2013-2016 8.4AN VP4-NA firmware files and share any 2013-2016 Schematics you may have!
- INFO - 2013-2016 8.4AN FW Notes (RA4/VP4 NA)
- My 2013+ Shared Schematics and other OEM Info
Mpgrimm2 is online now   Reply With Quote
Old 09-12-2016, 10:43 PM   #12 (permalink)
DavidN's Avatar
Ram Year: 2013
Engine: Hemi 5.7
Default
Hardest part is getting the mount covers off. lol
The rest is super easy.
Grab the mirror & turn it clockwise to unlock it.
DavidN is offline   Reply With Quote
Old 09-13-2016, 06:22 AM   #13 (permalink)
Mega-Hemi's Avatar
Ram Year: 2013
Engine: Cummins 6.7
Default
Thanks. I already have the 911/Assist buttons as well as the microphones on my mirror, hoping it will be just a plug and play, no harness. No clue why someone decided to cheap out on the auto mirror with everything else that's on this truck. I mean seriously, you've already got a shit load of electronics built into this mirror, how much more does it cost to add an auto dimming mirror? Maybe $10 on the manufacturing end! That and the fact that it's a 2500 Cummins that came from the factory without tow mirrors are something I will never understand.
Mpgrimm2 likes this.
__________________
2013 2500 Crew Cab CTD 4x4
Mega-Hemi is offline   Reply With Quote
Old 09-24-2016, 01:39 PM   #14 (permalink)
Mega-Hemi's Avatar
Ram Year: 2013
Engine: Cummins 6.7
Default
Ok, so I think the auto-dimming mirror I got is a dud. Does any of your auto mirrors have the little green light on it? My '06 had it, this one does not. I've driven to work twice now early in the morning and it's hard to tell if it's doing anything at all. The only way I can get the green light to turn on between the buttons it to press either the Assist or 9*1*1 buttons, then the light goes out when I cancel it. Does this sound right? Place I bought it from says there's a 90 return policy but I'd rather get it to work if I can. Checked the fuse (F101) and it seem fine. Not sure where else to look. Is there a sales code that needs to be flashed?
__________________
Old 09-24-2016, 03:38 PM   #15 (permalink)
DavidN's Avatar
Ram Year: 2013
Engine: Hemi 5.7
Default
I *think* with the 8.4 radio you will have the dealership to add a sales code in order to get the auto dim function to work.
On my 5.0/RA2 with voice control the auto dim works without an additional sales code.
(I can't turn it off through radio/evic tho, there's just no menu for auto dim settings.)
Old 09-24-2016, 04:04 PM   #16 (permalink)
Mega-Hemi's Avatar
Ram Year: 2013
Engine: Cummins 6.7
Default
Yeah, there's no setting in mine either, just wanted to get clarification before I went to the dealer. I've found multiple sales codes for the Auto dimming mirror, just not sure which one I am supposed to use. I found GN5, GNK and GNT with a JS family code. No clue which one I'm supposed to use.
__________________
Old 01-11-2017, 11:11 AM   #17 (permalink)
Ram Year: 2014
Engine: 3.6
Default
Got my Auto Dimming Mirror installed and will be heading to the dealership on Saturday to get the GN5 code added to my truck. Sounds like they've done it before cuz the service manager said "no problem". I will let everyone know how it goes.
I notice that the Auto Dim Mirror sits a little lower then the Manual Mirror I had originally, so that's why you need the different plastic covers. I see it also has a sensor on the backside looking forward, is that for Auto High Beam function??? Wonder if there is a code that can be added to make that work also???
__________________
Weathertech Floor Liner, Weathertech Side Window Deflectors, Weathertech Molded Mud Flaps, Line X Spray In Liner, Ionic Gladiator Running Boards, Extang Black Max Tonneau Cover LEDglow Tailgate Bar
stimpy433 is offline   Reply With Quote
Old 01-11-2017, 05:00 PM   #18 (permalink)
Ram Year: 2013
Engine: 5.7 HEMI
Default Part#s needed - 911/Assist auto dim mirror covers
I have never heard of anyone being able to get the code for AutoDim added. I believe several have tried and found it's one of many on the long list of codes dealers aren't allowed to add. The sensor on the front is for automatic high beams. I doubt that code will be available to you either.
EDIT: The high beam sensor is a separate piece that sticks off the front. If you're talking about the one on the mirror body itself, that's just the ambient sensor for the AutoDim.
00R/T is online now   Reply With Quote
Old 01-11-2017, 05:24 PM   #19 (permalink)
Ram Year: 2014
Engine: 3.6
Default
Well, I guess I'll find out on Saturday.... Hell even I can't get it to work I still like the fact that the whole mirror assembly hangs down lower. Sure makes it a lot easier to adjust and see out of in my truck.
__________________
Old 01-11-2017, 05:35 PM   #20 (permalink)
Mega-Hemi's Avatar
Ram Year: 2013
Engine: Cummins 6.7
Well I hope they can add it. I swapped my mirror a while back and have been waiting to have the code added till after I swap out mine to my tow mirrors.
__________________
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
auto dim mirror big_red06 Interior 3 05-04-2016 02:46 AM
911 Assist Mirror Install Question STYSMason 4th Gen DIY 7 11-18-2015 07:34 AM
driver door mirror plastic part broke....they said i need to buy a whole mirror.. daggertats Exterior 7 10-03-2014 06:14 AM
Adding auto dim mirror... DeputyDipShizz Audio & Electronics 4 12-16-2013 02:15 PM
Auto-Dimming Mirror Bigdaddy Interior 8 02-08-2012 09:25 PM
GM Truck Forum
Ford Raptor Forum
Chevy Tahoe Forum
Chevy Cobalt Forum
Chevy Camaro Forum
Toyota FJ Cruiser Forum
Ford Truck Forum
88-98 GM Truck Forum
73-87 Gm Truck Forum
Ford Expedition Forum
Chevy Equinox Forum
Chevy Cruze Forum
Jeep Liberty Forum
Jeep Forum
Dodge Ram SRT10 Forum
Chrysler 200 Forum
Scion xD Forum
Scion xB Forum
Dodge Challenger Forum
SRT Forum
Nissan Titan Forum
Buick Enclave Forum
Cadillac Forum
Cadillac XTS Forum
