Please help -- weird rattling noise
ttab88
HEMI 5.7
https://vimeo.com/224646436
2014 RAM 1500 Sport
Weird rattling noise coming from what seems like driver side behind the dash. Only happens when going 50+mph. Used to be a mild annoyance kinda like a chirping sound. Now it's extremely bad, so now I know something is definitely not right.
SportyJames
Corpus Christi
2015 RAM 1500 Sport
I have that same "chirp". Mine seems to be down by the kick panel.
Have you ever run any wiring through your clutch delete plate?
T
ttab88
HEMI 5.7
No, I haven't. I'm planning on taking it to the dealer or a mechanic shop to hopefully see if they can figure out the source because I've looked everywhere and I can't figure it out. I don't think it's anything loose because it only happens when driving it higher speeds. The noise also gets louder when I press on the brake at higher speeds. I'm thinking it's something wrong with the brake system.
breal201999
2014 RAM 1500 Sport
I had the same noise and was about to take mine in as well, but I couldn't always duplicate it. So, I stuck my head under the steering column with a pack of zip ties thinking I was going to tie any and every loose wire, and the only cable I could see zip tying up was the one connected to the hood release. Attached is a picture where I zip tied. Three months later, no rattle. Hope this helps and best of luck.
T
ttab88
HEMI 5.7
I'll try that. How does that cable cause rattle noise though?
SportyJames
Corpus Christi
2015 RAM 1500 Sport
The reason i asked about the delete plate is because i have run drilled a hole in it. I thought noise could be something coming through the hole from the engine compartment. I am going to try the hood release cable. Fingers crossed.
breal201999
Honestly, not sure. Just a guess, maybe the squeak is further up the cable going through the firewall and the zip tie stabilizes it?
T
ttab88
HEMI 5.7
Zip tying that cable didn't help unfortunately. I wouldn't mind if it was quiet but this is really loud as you can hear in the video. Does the fact that it ONLY happens at 50+ mph mean anything? It's the weirdest thing, I can drive 45mph and there's nothing. But the instant I hit 50 the annoying loud rattling happens.
Mustangmike66
South Korea
N/A
N/A
I have the same rattle. My best guess is it's from the cover behind the rear view mirror. The wife says it's loud when on the phone over Bluetooth.
T
ttab88
HEMI 5.7
Does yours also happen only at 50+mph speeds?
I'm going to take the truck to the dealer this weekend. Still under warranty. I've tried looking more on google to see what else I could find, except this time I expanded my search to other vehicles also. Someone with a Jeep Wrangler had similar issues at 30+mph and the dealer replaced the axle shaft and the noise was gone.
Since the chirping only seems to happen at 50+ mph, I'm sure it can't be anything like loose cables. Those would be heard at any speed. But it's funny you mention bluetooth though because the sound almost does sound electronic in nature... something like the sound that radio interference makes. Hm.
WISluggo
2013 Longhorn
I have this exact same sound; but it only appeared after getting my new set of tires in October. It only happens between 54 and 62 MPH in my truck.
T
ttab88
HEMI 5.7
Did you put in the tires yourself or did you have a shop do it? If it was a shop, I'd take it back and have them take a look at it.
Mine actually didn't start popping up until I had Firestone do a free inspection on my brake system and suspension system. Not sure if it's related because it wasn't noticeable right away, and it gradually got worse, but that's the last time anything was done to my truck before this noise started.
WISluggo
2013 Longhorn
My Ram dealer put my tires on, and I forwarded the service manager a link to your video for their thoughts.
T
ttab88
HEMI 5.7
Thanks, I appreciate that.
I made a service appointment at the nearest Dodge dealership, but the next available isn't until Wednesday next week. Guess I'll have to wait and see..
RamCares
Michigan
n/a
n/a
Hi ttab88,
Sorry to hear about this! Please don't hesitate to PM our page with any questions or concerns that may arise during your service appointment, we're here to help if needed.
Andrea
Ram Social Care Specialist
WISluggo
2013 Longhorn
Have you looked at the thicker gauge black wire that runs from firewall to the parking brake? Mine was resting on what looks like a heat sink fan that might be the cause. Not sure yet since I just looked at it.
John Kudranski
Pittsburgh
2014 RAM 1500 Sport
I’m having the same issue on my ram 1500!! It’s a 2017, what did you do to fix it?
SavageNomad
midwest
2014 RAM 1500 Sport
DID YOU EVER FIND THE ANSWER?!?!?!?!?
I have a 2016 Ram 1500. Have the same chirp sound. It's driving me nuts!!!
