ok here we go new here so bare with me.
i ran out of sunlight and began to get frustrated.. i wired it up just as everyone said tapped the 2 wires in drivers column and ran them to the ground and switch power. then i taped green plugs center wire that gave me a weak constant power. the green plug only had the 2 wires being used that ran up drivers column for the dome light.. i tapped the center wire on the opposite side of plug then the 2 wires for dome light. like i said it was giving a weak light on my test light..
wired it up like directions said that came with the console.. map light only work when i push the button and both map light come on when i push one.
second the map lights do not light with the door open..
going to recheck wires in morning but shouldn't only one map light come on when button is pushed.. sorry if in not making sense this is driving me crazy
2014 ram 1500 express 5.7 4wdhttp://www.ramforum.com/images/smilies/baby.gif
