shifter handle
jojo750
south carolina
v6
i have a 2011 ram with the center console.
please inform me how to remove the handle from the shifter?
ive looked for set screws, even tried twisting it. but stopped doing that before i broke something.
im thinking about switching out to the chrome mopar "T" handle, but wanted to know the removal process before i made the purchase.
thanks for any info.
i truly appreciate it.
joey
0212353
Vendor
Florissant, MO
2x 5.7L & 6.2L
you have to stick a very small screwdriver between the handle and that little U shaped thing under it. push it down, the handle comes right off.
Ram725
Jackson TN/Houston Tx
2012 Ram 2500 Crew 4x4
6.7 Cummins HO
What JJ said.. I put a laramie longhorn shift knob in and all you have to is stick something (I used a knife) between the chrome plastic trim and the shift knob and separate the two. Mine needed some force but also be careful not to bend the plastic. Very easy. Takes 5 minutes
C-Mack
2012 Dodge Ram Big Horn
Post some pics of your handle once it's installed.
jojo750
jojo750
south carolina
v6
another quick question.
when looking for a new handle, some are made for the ram's and some are for the challenger/chargers. is there any difference between them?
i dont know the correct part# offhand, but wanted to see if anyone does know.
thanks again
10ramsport
Sherwood, AR
Or you can go custom and shorty like I did.
Lhemi
OKC OK
6.7 Cummins Turbo & Hemi 5.7
Love the Hurst shifter! Where did you get it?
powderbrad
Edmonton, AB
Got a burnt orange T handle coming...should be here in a few days time. Ill let you know guys know. Hope it looks good.
Came in here for the removal info :)
powderbrad
Edmonton, AB
Couldt be easier to remove the shifter. Pull silver trim piece down. handle up. Done.
If I could post pics Id show you a nicely anodized BT Hemi shifter!
w4rmk
Colorado
Does anyone know if any changes were made between 2011 and 2013? I want to purchase a leather shift knob but the one I found says it only fits 2013 Rams.
Sybil
Can you tell us how you did this? Parts or adapters? I got to have this but I want the black Hurst ball!!!
