Where have you installed switches???
Icejob8
Saratoga NY
I am going to install an LED light bar in the front, "rock" lights underneath and reverse lights. I am going to wire the rock lights to come on with dome lights, reverse on when in reverse, BUT I want to be able to manually turn them on.
So, where have you guys been installing your switches?
PLEASE post pictures if you can, thanks!
monteholic
Michigan
6.4 hemi
picture.php
Icejob8
Icejob8
Saratoga NY
I was considering that location. Any chance you have any instal pics, or an explanation of how and where you ran wires?
monteholic
Michigan
6.4 hemi
that location might not be a good idea if you have a 1500 with the 8 speed, the manual park release is behind that panel
I ran the wires thru where the clutch master cylinder would be
MarshRam
Florida
2014 SLT 4x4, 2012 ST
That may be your best location that monteholic mentioned. I'm going through the same issue and didn't want to drill into the panel. I have this cheap rig up going right now. When cruising the county roads at night, where I have it can be a pain to get to quick enough to turn off with oncoming traffic. If you use it in that manner, make sure it is somewhere you can access quickly, especially if you get a quality bar, they are ridiculously blinding and can no doubt blind and run someone off the road. Im just going to have to mount it right and if the future owner doesn't want the light bar, they can deal with replacing the panel...
Icejob8
Icejob8
Saratoga NY
I don't know if this helps, but I anticipate 3 switches but there could also be more. I like the rocker switches with led light on them...think they are about 1.75" deep plus a little more room for wire terminations.
I think a great idea would be on the roof console to the rear of sunroof and back window controls. The factory controls lay horizontal and I was thinking about installing these new switchs "vertically"
Hopefully someone has done this????
69GWC
Power Wagon
Spring hill, Kansas
2022 Power Wagon
6.4 Hemi, 8sp
What I did, debated on this for a day and could not find anywhere else that I liked better and had nothing behind it to get in the way.
I left room to put another one beside it if need be.
MarshRam
Florida
A lot more work, but that would be nice!
Icejob8
Icejob8
Saratoga NY
I want to use the rectangular switches, so they won't fit right there but I was also thinking about 4" closer to steering column. My concern there is a lack of space behind the panel, don't know bc I haven't checked.
Any idea of space available???
69GWC
Power Wagon
Spring hill, Kansas
2022 Power Wagon
6.4 Hemi, 8sp
I cant remember for sure but I think when you get close to the steering wheel there is less room behind it.
MoreOvalteenPlz
Stillwater, OK
This spot works great for my '13 (6spd) because there is nothing behind it and it is a $5 panel to replace if I ever need to take the switches out.
Red switch - LED light bar on grill guard
Green switch - unused (for now)
Blue switch - rear LED pods
muddy12
Indiana
I like that. May have to mount mine there.
There is plenty of room for wiring behind the cover, and enough space for 3 of the large switches like I have(maybe more if you use smaller switches) [emoji106]
Demon-HeMi
Houston
2003, 2003, 2008, & 2013
(2) 5.7 HEMI, 3.7, & 3.6
This spot works great for my 13 because there is nothing behind it and it is a $5 panel to replace if I ever need to take the switches out.
if you have the 8spd trans you cant out anything there, that area has the emergency park release behind it on our trucks
02ramboi
live oak florida
4.7 v8
Installed mine in the side of the steering column cover.
I like where that is installed good idea for my next switch
4.7 v8
Hi flow cat/flowmaster exhaust
7 inch lift/5 inch lift
20 inch falken wildpeak at3/33's
1Popeye
