Wiring harness under rear crew cab seats
kyndacrazy
I have a 13' Big Horn Crew Cab. Can anyone tell me what the empty wiring harnesses under my rear seats are for? There is one on each side near the back corner closest to the door.
magz
New Ulm MN
Hemi 5.7 E-Torque
Maybe for heated seats? I have those in my Laramie
K
kyndacrazy
Can you check to see if yours has a wire connected to the other end of the harness? It is very easy to see if you lift up the seat bottom.
Steve21
It's for the heated seats/led lighting some trims have. My truck has this harness that does not connect to anything...
baum
savage, mn
2015 Laramie
or is it for the factory sub? i was told there is a factory sub harness in there even if you dont have the factory sub
Lawrencec346
Tennessee
Yes I have a 2013 express it has the two white plugs on each side but not wired to anything, trying to put in footwell lights I bought the wire but no wire to plug into ,under my carpet on the passenger back seat there is a hole with amp wire umber it
Keifus
Midland tx
3.6L V6
They are for if you decide on putting a amp and speakers back there. If you pull your stereo out you will find them dummy plugged in the plastic surrounding the stereo hole.
thkbaron
Minnesota
well it's not for the sub. as I have one and that plug is empty. I can't recall if I have the lights. I'll check tomorrow.
GTyankee
El Cajon Calif. 92021
3.0 ecodiesel
What i can't put my cursor on, is why Ram put such a large 6 connector plug on something so seemingly unimportant
They could have used a 2 wire connector
Rear seat heating would explain a bit
I found a website for Chrysler Connectors
such as:
HEATER-SEAT BACK-LEFT​
Full Repair Kit: 68087932AA​
Then they have an image of the part
Benny's name was mentioned on the site where i discovered it
thkbaron
Minnesota
yeah I'm sure it's for heated rear seats more than likely. They probably just used that plug so they didn't have to reproduce another one. Makes it simple. Or outsource a different one.
Moose2
Iowa
Well then, what would be involved in hooking up heated seats in the back? Do tell if known.
