[emoji15]Hemi Tick or Broken Bolt?[emoji848]
Casper
U.S. Navy (Ret.)
Springfield, VA
5.7L
Another question...
Will my S&B and Magnaflow weld on muffler void this warranty repair??
No. Burden would be on dealer to PROVE your after market modifications were the cause of the failure (Take turn on the ole inter-web to review the Magnuson–Moss Warranty Act P.L. 93-637).
How could FCA do that when just about every Hemi they've built eventually has an exhaust manifold warp or bolt break???
Ghost2013SCC
Ghost2013SCC
I did some Googling after I posted and saw the Warranty Act.
Golden cobra
Every Hemi that I have had to this day except my 2014 ram 1500 has broke exhaust manifold bolts. I have replaced them on my 2003 2500, my 2004 2500, my 2007 Durango, and my 2006 Jeep Commander. The commander was the only one I could not get to the bolts so I actually found it easiest to pull the heads with the manifolds on and replace it outside of the vehicle.
Sent from my SAMSUNG-SM-G930A using Tapatalk
Ghost2013SCC
Ghost2013SCC
My 2010 Commander is still going with 265k on it. I replaced the water pump, alternator, and starter aside from regular maintenance. My oldest daughter drives it now.
smiley
Minot, ND
2014 Ram 2500 Crew
6.7L Cummins
Just started this morning. 2013 Sport w/72k on odometer. It'll go away after it warms up and drive off for a minute or less. What y'all think??
https://youtu.be/TzydIBNRfio
Broken exhaust manifold bolt final answer. Probably a warped manifold caused it to snap.
Ghost2013SCC
Ghost2013SCC
Thanks for all the feedback. Now I need to decide which headers. I don't want longtubes cuz I'm not getting a tuner. This is my DD and I'm constantly on the highway traveling for work. So I'll be going with shorties. Which brand...BBK, JBA, or Flowtech?
H1Chester
I had BBK shorties on my Camaro at one point. Good product and affordable.
smiley
Minot, ND
2014 Ram 2500 Crew
6.7L Cummins
Ghost2013SCC
Ghost2013SCC
I got this setup but still need to install.
BBK (40140) 1-5/8" Silver Ceramic Coated Shorty Tuned-Length Exhaust Header for Dodge Truck https://www.amazon.com/dp/B007V97KKG/ref=cm_sw_r_cp_apip_mL1LCSHNhpRb1
And
Stage 8 - 8916 MOPAR 4.7, 5.7, 6.1 Liter Hemi V8 Header Bolt Kit - 8mm 1.25x25mm Bolts 6 Point DHH - Set of 17 pieces https://www.amazon.com/dp/B000QDX8LE/ref=cm_sw_r_cp_apip_JfImP4m2Bp61F
What gaskets are you going with?
Ghost2013SCC
Ghost2013SCC
So with shortie headers one doesn't need a tune?
No tuner needed. They just replace the factory manifolds and bolt up to the rest of the existing system.
