california
- May 10, 2013
- 482
- 48
- 2013
- Hemi 5.7
so this just happened
first pull with 150shot 100octane launch of the hole real good
air to fuel ratio 10.9 11.2 11.5
second pull 150shot 100octane sprayed of the hole changed the gas jetting from 28 to 24 air to fuel ratio 12.2 11.9 11.5 11 2
third pulls before launching was preepin heating up my tires when heating up my tires. it was backfiring from the exhaust with nitrous off, everything off just heating up so i launched with nos off just to see if it kept doin it it backed fired loud came driving home slowly backfired couple time in betweeen gears did i **** up my engine.
check engine light came on
p0307 cylinder 7 misfire detected
so i digged into my plugs and this is what i found
using a air to fuel ratio wideband on 150 shot what is consider rich and what is consider lean ive been hearing all kinds off numbers im just confused right now what are the numbers im suppose to see on the wideband with 150shot with 85mm hemi plate system n20?
i will replace those 2 plugs this morning hopefully it didnt damage no internals
