1/4 miles runs
california
I dont know if the 1/4 mile test on the diablosport trinity tuner t1000 is legit as i havent had a chance to go to the track and get me some numbers which would be going in a couple of weeks. So i decided to do the 1/4 mile run with the tuner on a great sticky road thats out here no tire spinning on none of the runs.
If the programmers quarter miles is not legit please let me know!!!!!
1st pull 14.03 at 94.0mph
2nd pull 13.87 at 97.5mph
3rd pull 13.25 at 97.5mph
4th pull 13.73 at 98.5mph
13 ram single cab 6 speed trans
Mods on truck are the following
1st vararam intake
2nd 87mm ported throttle body
3rd arh longtubes 1 1/4 with cats
4th edge racing 3000 stall converter
5th upgraded gears 3.55 to oem 4.10s
6th hps moes camshaft with upgraded valve springs retainers and shims.
7th oil catch can, and a 3" raceland electric exhaust cutout
8th last but not least diablo sport trinity tuner t1000 with a hemifever tune!!!!
Stock 20's front and back
Fronts nittos 305/50r20
Rears nittos 315/35r20 drag radials
Have tailgate on and spare tire still on truck.
3inch level front and back dont know if that kills time or not.
If this is legit what do i need to work on to beat that timing
Upcoming mods
Possibly ported heads found a good pricing with precision as i already have valve spring kit installed
Under drive pulley
Nitrous
Thermostat
Transmission cooler to keep a little cool
Smaller wheels
z28th1s
Lynchburg, VA
Considering you said you didn't spin on any of the runs there is a large variation in the times, almost 8 tenths of a second. I personally don't think the times you get from those tuners are that accurate.
Take it to the track then you will know for sure.
Tomater03
I believe the truck is faster than that, with those mods I would think high 12's at 104-106 with a dialed in tune. Get that booger to a track. Fastest I've gotten mine to on the Diablo is 8.44 at 88 mph on the trinity with the 1/8th mile setting, it just ran a 7.96 at 86 last Friday. After that, I won't use it anymore as its not a good indicator of what the truck can actually do.
Hemi450hp
Moe's Performance
Conroe, TX
2014 Ram 1500
The 1/4 mile feature on the tuner is fun to play with, but as stated, isnt very accurate. Your mod list has the potential to put you in the 12's easily with traction and a little prep.
california
california
I will have to take track wheneer i have a chance to see the timing on this truck curious to know
