Witch
- May 6, 2016
- 1,295
- 630
- 2015
- Hemi 5.7 liter
2009 2016 Dodge RAM Series Billet Catch Can 5 7L 6 1L 6 4LHEMI Black Anodized | eBay
The occ can came today US Postal service Priority Mail.
I thought this was a Bilet product and it may very well be.
However it is not stamped on the lid like the ones on Moe's site
Thinking it is a Chinese knock off
That being said it seems to be of high quality none the less. Nicley finish anodized aluminum. Reason I went this way was you get the black upgrade and the nickel plated fitting for what amounts to 10 less than the vanilla unit.
My thought process was for it to blend in in the engine compartment, and it certainly does. If you are looking for contrast , go silver or one of the many available colors. This one also has a bleeder port at the bottom that I am not very happy with. Reason being with the valve in the closed position you can not unscrew the bottom canister ??? , smooth move by the engineer ..... lol
I bent it down for now as you can see in the picture, I will either get a plug or just leave well enough alone as I intend to unscrew the unit to empty it.
Really all you need to do is use a lager spacer against the block where the bracket mounts. Talking about the bracket, it is beastly and more than enough to hold this unit for the life of the truck and then some.
All in all I am thrilled with the the unit and got the color I wanted for less than I thought I was going to have to spend.
The other high light is I go to use my new set of tools, while not a big deal to most, after installing my CAI with a pair of pliers, adjustable wrench and a butter knife life is good
Included in box
ready to install
Handle mod
Install with connection points & engine cover off
Back together
Included in box
ready to install
Handle mod
Back together
