I'm new to this forum. I'm trying to find out has any one had any timing chain issues out of the 09 and up 5.7. Replaced the Cam phaser and new timing chain kit after getting a crankshaft mis alignment code. Cam phaser was faulty. Drove vehicle for a few weeks and the timing chain breaks. So I had to tear it back down and pull the heads. Bent a few valves. Sent the heads off to a machine shop. After I got everything back together atempted to start the truck. It ran for a couple of seconds then it shut off. Would not turn over. Took a wrench and tried to turn it over by hand at the crankshaft, it would not budge. Pulled the oil pan and noticed the crank is trying to turn but the cam is not moving. Pulled the valve covers also and took all of the rockers arms loose. Checked to see if I dropped a valve. Nope all 16 are still in place. Engine still won't turn over. It feels like something is binding. Any thoughts or comments would be appreciated.
