Raist11
Been a while since I've been around here.
My baby has a radiator leak. Replacing the Jeep's radiator this summer wasn't enough.
Now I just started poking my head around, pulled off the grille. I can't see an obvious petcock/drain for the radiator. I've been surprised how little info online I can find for a 4th gen as well. Anything I have found says it's on the passenger side? But nothing obvious there. On the driver's side though I see a spout/pipe come off the rad horizontally with a hex head beside it. It's not the usual valve I'm used to but is that what I'm looking for?
Yes, I can just yank off the lower hose and let the coolant splash around all over, but I'd rather not.
If anyone knows of a good write up for the 5.7 hemi I'd appreciate it. Most of what I've found is for 3rd gen. I'm thinking I'll be wishing I was replacing the Jeep's radiator again by the time I'm done with this thing.
