My 2013 Ram Bighorn 1500 with 5.7 Hemi and 3.55 gears has a listed tow rate of 8,850 lbs. The same year truck with the same engine but with 3.92 gears has a listed tow rating of 10,300 lbs. Does anyone know if the factory modified the truck with the 3.92 gears in any way to achieve the higher tow rating, such as bigger brakes, heavier suspension, transmission cooler... I will be towing a 9500 lbs trailer and the simple fix would be to change out the 3.55 for the 3.92 gears.
