tommy_harrell
- Feb 4, 2014
- 31
- 3
- 2014
- 6.4
I have had my '14 6.4 since February and I'm at 2800 miles.
8 times I have bumped the key to start, the engine cranks for 10 seconds and doesn't start. It has always started on the second try, but not as well as when it starts on the first try. Most recently it said "Service Electronic Braking System" when it failed to start, but the message went away when it started. No check engine light.
Hooked to a little lawn mower trailer that had a marker lamp wire shorted out and I popped fuse "F29" the manual says fuse F29 is a 20a yellow cartridge fuse, but it a 20a blue cartridge of some kind, Smaller than a low profile cartridge. I pulled the trailer backup lamp fuse (f28) and installed it in the marker location (also miss identified in the manual as a yellow)
This new truck has 3 different styles of fuse, so when you are gathering spares you will need several
If anyone knows of a part number of even a name for the cartridge fuse, it would be greatly appreciated.
Tommy
Tommy
