Go Back   DODGE RAM FORUM - Dodge Truck Forums > Dodge Ram Generations Forum > 4th Gen : 2009 - Present > Engine & Performance
2014 go fast parts
This is a discussion on 2014 go fast parts within the Engine & Performance forums, part of the 4th Gen : 2009 - Present category!
ok so I've had my truck for almost 2 weeks and already put in bilstein 5100 set to max 2.8 ...
Like Tree1Likes
Sponsored By: Moe's Performance
Reply
Old 10-17-2014, 07:22 AM   #1 (permalink)
Ram Year: 2014
Engine: hemi 5.7
Default 2014 go fast parts
ok so I've had my truck for almost 2 weeks and already put in bilstein 5100 set to max 2.8 and a flow master super 40. I'm looking at a vera ram intake and a 87mm ported throttle body also. but my truck has the open diff so i have a lsd on the way and from what i hear 4.56's show the biggest improvement. so my question is what will i need to switch to the 4.56 gears and what other mods should i be looking at to go faster.
Sponsored Ad
Register to remove this ad.
jstacey8 is offline   Reply With Quote
Old 10-17-2014, 08:43 AM   #2 (permalink)
Ram Year: 2011
Engine: 5.7
Default
You're gonna need a whole front axle from a 2011 or older truck to get 4.56s on the front.
The rear LSD will also need to be machined to fit the old bolt pattern of the 4.56s.
TylerB is offline   Reply With Quote
Old 10-17-2014, 08:58 AM   #3 (permalink)
charonblk07's Avatar
Ram Year: 2009
Engine: F1-A forged 349ci
Default
A new front axle. You can't just swap out the gear set on the front diff like older years, it'll require an older front diff to be swapped into the front to run 4.56s. The largest you can get in a factory front is 4.10s.
__________________
'09 Ram 1500 Sport 4wd Green Mamba- 4.5/6.5 dropped, forged 349 block, cog driven F1-A Procharger
charonblk07 is offline   Reply With Quote
Old 10-17-2014, 09:13 AM   #4 (permalink)
Ram Year: 2014
Engine: hemi 5.7
Default
would it be worth it to go to 4.56's or are 4.10's a better choice money wise? ill also be getting a TC in a little while so whats next headers?
Old 10-17-2014, 11:56 AM   #5 (permalink)
Hemi450hp's Avatar
Ram Year: 2011 Ram 1500
Engine: 5.7L Hemi
Default
Unless you are ready to spend $3500 on the gear swap, I would go with the longtubes, custom tune and tq converter. Do these 3 before the intake and throttle body if your funds allow.
dtru1222 likes this.
__________________
2011 Ram 1500 - 11.99 @ 110.66MPH N/A
2011 Ram 1500 - 11.09 @ 120.13MPH Nitrous
2014 Ram 1500 - 12.38 @ 109.61MPH N/A
Hemi450hp is offline   Reply With Quote
Old 10-17-2014, 12:18 PM   #6 (permalink)
HemiPower36's Avatar
Ram Year: 2014 Ram 1500 Laramie 4x4 3.92 8-speed
Engine: hemi 5.7
Default
What gearing did you get from the factory? Should have gotten 3.92 with the lsd. Research research research before you walk into the dealer. Know what truck you want and why. Don't worry, I am not hating on you, took me three times to learn that from previous truck purchases. The 3.92 is a 50$ option and I am sure the LSD is not far off that too.
Unless you have plenty of $$$$$ then you have to work with what you got.
HemiPower36 is offline   Reply With Quote
Old 10-17-2014, 12:49 PM   #7 (permalink)
Ram Year: 2014
Engine: hemi 5.7
Default
i have the 3.55 gears with the open diff but want lsd because one tire fire is pretty embarrassing. but I'm trying not to void my warrantee quite yet. and for headers i have no clue what to go with as there are so many to pick from so if you could point me in a good direction
Old 10-17-2014, 01:42 PM   #8 (permalink)
OilCityOperator's Avatar
Ram Year: 2013
Engine: 5.7 Hemi
Default
Hey bud sorry to kinda hijack your thread but how do you like the bils set at 2.8 ? Im throwing them in my 13' this weekend I want em maxed too but mostly im seeing guys go 2.1..any issues so far ? Wobble im 4x4?
__________________
2013 Sport, AFE Stage 2 Intake, Muffler Delete, Black 5" Tips, Bully Dog Hemi+, Bilstein 5100's @ 2.1, Tint, Dipped, De-badged, XD Spy's 20x9 -12 with 1/4" wheel spacers, 35's
2001 Dodge Cummins, 24v, NV5600, Super B Single Turbo, SouthBend Dual-Disk Clutch, AFE Intake, Intake Elbow, Edge Juice/w Attitude, 4 Inch Straight Pipe, 6" Suspension Lift, XD Rockstars, 4th Gen Bumper, Sunroof
OilCityOperator is offline   Reply With Quote
Old 10-17-2014, 01:54 PM   #9 (permalink)
Ram Year: 2011
Engine: 5.7 Hemi
Default
Matt, what kind of gains do you get with long tubes and what's the cost?
Jsta, do yourself a favor, and educate yourself on the factory "Anti Spin" and the Detroit True Track, and what to expect from each, and the cost of installation. The Anti Spin does ok once you learn its limitations. Heck, even I can do a nice smokey dual burn out now!
If it's a 14, then you have the 8 speed, right? You 8 speed guys have a really nice low first gear, so I'd do what Matt says. If it was a 5 or 6 speed, I'd be screaming gears. And the lower, the better in those.
RLJ10X is offline   Reply With Quote
Old 10-17-2014, 02:16 PM   #10 (permalink)
Hemi450hp's Avatar
Engine: 5.7L Hemi
Default
Longtubes are putting out about 25hp/tq to the wheels. I have a handful of customers now that have dyno'd gains of 60hp/65tq from just longtubes and a Hemifever tune. We are seeing similar gains from both ARH and JBA. The ARH setup is more complete, and I like the option of running the 1 3/4" primaries to get more tq for daily driving...also, the option to run high flow cats is a necessity for most states. The 1 7/8" primaries on the JBA's are nice if you have gears and a converter to make up for the lack of tq down low though.
Stainless JBA's with off road y-pipe is $833, ceramic coated JBA's with off road y-pipe is $978, and stainless ARH with cats is $1665 for the 1 3/4" primaries.
__________________
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
2014 2500 Black app group parts Timgco Exterior 8 10-05-2014 11:31 PM
Need Serious help fast! BlazersandWildcats Engine & Performance 4 06-24-2014 11:01 PM
2014 Ram parts wanted.. 14RAM1500HEMI Wanted 2 03-05-2014 10:56 AM
2014 Performance Parts vinyldecals Engine & Performance 6 11-05-2013 12:04 AM
GM Truck Forum
Ford Raptor Forum
Chevy Tahoe Forum
Chevy Cobalt Forum
Chevy Camaro Forum
Toyota FJ Cruiser Forum
Ford Truck Forum
88-98 GM Truck Forum
73-87 Gm Truck Forum
Ford Expedition Forum
Chevy Equinox Forum
Chevy Cruze Forum
Jeep Liberty Forum
Jeep Forum
Dodge Ram SRT10 Forum
Chrysler 200 Forum
Scion xD Forum
Scion xB Forum
Dodge Challenger Forum
SRT Forum
Nissan Titan Forum
Buick Enclave Forum
Cadillac Forum
Cadillac XTS Forum
